0 members (),
527
48
Topics49,841
Posts837,323
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Header gasket is Harley Evo ('84 and newer) spec, so pretty common. I've had very good results with the James brand gaskets (hollow copper ring with stainless mesh inside). Much easier to fit than the stock tapered graphite/mesh things. https://www.jamesgaskets.com/product/jgi-65324-83-cg/
Steve Late 2012 M3W
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I've been checking to see whether the ARP studs are available from a UK supplier but it seems that they are specially made under licence for Hillcofasteners in the US.
Anyone want to get together to order a batch to minimise postage costs?
Andy
Posts: 1,338 |
I just removed the pipes to polish them & get things ready for the new studs/nuts. I noticed that the lower nut of the header pipes was very easy to break loose
Posts: 902 |
Hi John, I'll wait a week or so to get a better idea on numbers then see about getting a quote. At the moment, I'm thinking of a kit consisting of: 5x Studs (one spare because you never know) 8x Jetnuts (one spare set) 4x James Gaskets (one spare set) Stay tuned!
Andy
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Header gasket is Harley Evo ('84 and newer) spec, so pretty common. I've had very good results with the James brand gaskets (hollow copper ring with stainless mesh inside). Much easier to fit than the stock tapered graphite/mesh things. https://www.jamesgaskets.com/product/jgi-65324-83-cg/ We use something very similar on older gold wings. On a couple of my barn find projects, I have discovered more than one crush gasket when I took off the headers
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Some parts will be here tomorrow, others arriving Friday, so I decided to just hang for a week and remove front wheels for new tires and tubes added to manifold studs and nuts. All are due and I could never pass inspection anyway. It was over two years ago that I did this and I used Loctite liberally for all the mounting bolts and they are just a bunch of fun to remove! But they were still attached so that's a win!
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
I put cross tube No more puncture.
I put cross tube No more puncture. ??
Steve Late 2012 M3W
Posts: 1,338 |
When I removed the headers, there was no gasket only this spacer on the headers [url=[URL=https://s1349.photobucket.com/user/Q8morgan/media/1844D848-0A56-4A45-A00D-60B6388839BB_zpsudhisnij.jpeg.html]  [/url]][/url] . [url=[URL=https://s1349.photobucket.com/user/Q8morgan/media/CCB879F5-69A4-4D9D-89F3-4F72A1C54207_zps9mx5kdvd.jpeg.html]  [/url]][/url]
