7 members (Image, MavisTheMorgan, Gramrugby, sewin, Grumpy2, sbarracl, Biggle),
198
Topics49,838
Posts837,294
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I Just protect to stainless cheeks and give 'em a little squeeze with some parallel water pump pliers
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
My new Pins have arrived (thank you again Paul).
What is the recommended way of enlarging the holes to fit? I have read about a 7mm reamer? Can I just bang the reamer down, or will I need to drill them out a bit first? I think they're about 6.5mm at the moment.
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
I’ve bought an adjustable reamer that covers 7mm. I think one half of the hinge needs to be tight and the other half a bit slacker.
Never used a reamer, do they have a very slight taper at the end to start them off?
Thinking I drill out to about 6.75mm and then pass the 7mm reamer down the hole?
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
If it's a hand reamer then yes it's tapered for the first 15 to 20 mm. A hand reamer is one that has a square on the blunt end so that it can be turned (clockwise) with a tap wrench. 6.75 or 6.8mm should be fine for the drill. Use some oil on the reamer to help with the cutting. Cheers John
If it's a hand reamer then yes it's tapered for the first 15 to 20 mm. A hand reamer is one that has a square on the blunt end so that it can be turned (clockwise) with a tap wrench. 6.75 or 6.8mm should be fine for the drill. Use some oil on the reamer to help with the cutting. Cheers John Thank you, much appreciated.
