5 members (BLUE+4, Hamwich, stumog, Topline123, Stephen888), 342 guests, and 32 robots.
+8Rich 92
Topics49,838
Posts837,296
Page 4 of 4 1 2 3 4
TBM #718137 15/09/21 03:14 PM
I Just protect to stainless cheeks and give 'em a little squeeze with some parallel water pump pliers
TBM #718404 17/09/21 03:54 PM
TBM Offline OP
My new Pins have arrived (thank you again Paul).
What is the recommended way of enlarging the holes to fit? I have read about a 7mm reamer? Can I just bang the reamer down, or will I need to drill them out a bit first? I think they're about 6.5mm at the moment.
TBM #718418 17/09/21 05:27 PM
I’ve bought an adjustable reamer that covers 7mm. I think one half of the hinge needs to be tight and the other half a bit slacker.
TBM #718476 18/09/21 10:35 AM
TBM Offline OP
Never used a reamer, do they have a very slight taper at the end to start them off?
Thinking I drill out to about 6.75mm and then pass the 7mm reamer down the hole?
TBM #718486 18/09/21 11:51 AM
If it's a hand reamer then yes it's tapered for the first 15 to 20 mm. A hand reamer is one that has a square on the blunt end so that it can be turned (clockwise) with a tap wrench. 6.75 or 6.8mm should be fine for the drill. Use some oil on the reamer to help with the cutting.
Cheers
John07 #718487 18/09/21 11:54 AM
TBM Offline OP
Cheers
Thank you, much appreciated.
Page 4 of 4 1 2 3 4
