1 members (Ian B),
319
104
Topics49,867
Posts837,614
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
The hood release mechanism seemed to be getting more and more reluctant to undo when lowering the hood or or just stowing the shopping. Pulling harder and harder on the release handle seemed like a recipe for disaster, "something's going to break". So on the basis of Do A Job Properly, off came the spare wheel/cover and luggage rack, and by lubricating the universal joint on my neck I could see what the problem was. It is a simple two-part sliding latch, and it appeared the mechanism had not been greased since leaving the factory 12 years ago. Some WD40 and then some proper spray white grease has sorted it, and it now releases with a nice "click". Just remember to push down on the rear hood rail when pulling the release handle. ![[Linked Image]](https://www.tm-img.com/images/2021/09/08/Latch---left-side-showing-direction-of-cable-pull.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
The hood release mechanism seemed to be getting more and more reluctant to undo when lowering the hood or or just stowing the shopping. Pulling harder and harder on the release handle seemed like a recipe for disaster, "something's going to break". So on the basis of Do A Job Properly, off came the spare wheel/cover and luggage rack, and by lubricating the universal joint on my neck I could see what the problem was. It is a simple two-part sliding latch, and it appeared the mechanism had not been greased since leaving the factory 12 years ago. Some WD40 and then some proper spray white grease has sorted it, and it now releases with a nice "click". Just remember to push down on the rear hood rail when pulling the release handle. ![[Linked Image]](https://www.tm-img.com/images/2021/09/08/Latch---left-side-showing-direction-of-cable-pull.jpg) Thanks, very useful
Kevin
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
When I got my MOG new I was allways thinking: when does the plastic handle break?
As I was new in Morgans I was far away from a look under the sparewheel. But I noticed that the Hamburg MORGANPARK has some better looking chromehandles.
Better looking and to handle. But now after two and a half year of ownership my knowledges are a little better.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
In addition, check the tightness of the two fixings in each catch
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
This is one of several videos on YouTube that demonstrates quite nicely how to lower/raise the hood https://youtu.be/AT6eQ44jqHM
Posts: 638 |
Well worth being aware - our Roadster cable snapped - bye, bye £300!
David H
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
Check the pins align properly with the catches, they are slightly bent and can therefore be adjusted by slackening and rotating to give a fore / aft / L&R tweak
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
I have come across several, including my own, where the securing allen bolts have been loose or even dropped out. That can cause latching issues, either not latching or not releasing. I always check their security as part of my annual service.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Greets René Rene It's not the handle that breaks but the screws which are very short pull out of the wood, don't ask me how I know
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Check the pins align properly with the catches, they are slightly bent and can therefore be adjusted by slackening and rotating to give a fore / aft / L&R tweak If you do adjust them make sure your don't get it wrong , They should curve inwards otherwise it is very hard to release.
