4 members (RedThree, nick w, Plus Four Guy, Pundit), 210 guests, and 64 robots.
+8Rich 79
DaveW 51
Topics49,866
Posts837,587
The hood release mechanism seemed to be getting more and more reluctant to undo when lowering the hood or or just stowing the shopping. Pulling harder and harder on the release handle seemed like a recipe for disaster, "something's going to break". So on the basis of Do A Job Properly, off came the spare wheel/cover and luggage rack, and by lubricating the universal joint on my neck I could see what the problem was. It is a simple two-part sliding latch, and it appeared the mechanism had not been greased since leaving the factory 12 years ago. Some WD40 and then some proper spray white grease has sorted it, and it now releases with a nice "click". Just remember to push down on the rear hood rail when pulling the release handle.
Thanks, very useful
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
X
X
When I got my MOG new I was allways thinking: when does the plastic handle break?
As I was new in Morgans I was far away from a look under the sparewheel. But I noticed that the Hamburg MORGANPARK has some
better looking chromehandles.
Better looking and to handle. But now after two and a half year of ownership my knowledges are a little better.
Greets René
2018 plus4 (sports green)
In addition, check the tightness of the two fixings in each catch
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
This is one of several videos on YouTube that demonstrates quite nicely how to lower/raise the hood https://youtu.be/AT6eQ44jqHM
dmh Offline
Well worth being aware - our Roadster cable snapped - bye, bye £300!
David H
Check the pins align properly with the catches, they are slightly bent and can therefore be adjusted by slackening and rotating to give a fore / aft / L&R tweak
I have come across several, including my own, where the securing allen bolts have been loose or even dropped out. That can cause latching issues, either not latching or not releasing. I always check their security as part of my annual service.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Black Rat
Black Rat
Greets René
Rene It's not the handle that breaks but the screws which are very short pull out of the wood, don't ask me how I know swear
Keith
2013 narrow bodied + 4 Ruby.
If you do adjust them make sure your don't get it wrong , They should curve inwards otherwise it is very hard to release.
