Morgan Aero 8
10 members (Burgundymog, Paulxj, DickJ, Sir Percival, TheRabbit, verysideways, Ian Wegg, Clipper, GrumpyPa, gaston), 308 guests, and 55 robots.
+8Rich 92
Topics49,837
Posts837,286
Page 2 of 5 1 2 3 4 5
KevinMcR #718174 15/09/21 07:30 PM
Kevin, obviously Revolutions should know their stuff but is it worth checking for fault codes with an OBD2 reader and then doing a full power down reset of the ECU, and flip the fan relay ?
KevinMcR #718176 15/09/21 07:43 PM
miles of smiles
miles of smiles
Send a PM if you need me, not having an aero, I don’t check in often
KevinMcR #718178 15/09/21 08:08 PM
Will do, cheers!
KevinMcR #718179 15/09/21 08:10 PM
I’ll be chatting with them soon about the SOR so will ask if the reset is worth a try as well in case they haven’t tried it.
KevinMcR #718269 16/09/21 05:26 PM
Sir S1'a'lot
Sir S1'a'lot
No they never stopped working but are on continuously once they start.
I’ll get it investigated when I get it serviced next
2002 Aero 8 S1
2023 Plus 4 (woman’s)
KevinMcR #718286 16/09/21 07:15 PM
Similar to mine now but with one fan running continuously but the second on mine not working at all.
KevinMcR #718321 17/09/21 06:05 AM
PJC Offline
Might be an all too obvious question Kevin but have you checked the actual fan motor on the one that isn't working? Whilst that may not fix the whole issue at least you'd have full cooling effect on the coolant.
Cheers, Paul
KevinMcR #718367 17/09/21 10:57 AM
Not sure what Revolutions have checked so far but they are apparently going to be hooking it up to a diagnostics computer as advised by the factory to try and control the fans manually via that so hopefully that will prove both fans are working.
I think she knows I’m selling and doesn’t want to leave!
KevinMcR #718410 17/09/21 04:25 PM
Sorry to hear your having issues Kevin, if you stick with it you will be rewarded - I think a few of us have gone through the pain and thought about the dreaded sale.. but it is worth it I promise!
Re the control unit I had the main one go wonky, this caused a load of random indicator and wiper faults (mostly not working intermittantly, i.e. whenever it rained). It was a big heavy silver module stored on the OS under the ally covers. Morgan called it a Bradley box (after the man who made it apparently). I had the last one at an eye-watering sum, which does raise a worry if it goes pop again..
Aero 8 GTN #11
KevinMcR #718457 18/09/21 07:33 AM
Smile, it confuses them
On mine the fan did fail.
When my temps started to go up I called the dealer and they told me to turn on the AirCon. Apparently the AC turns on the main fans so you hear them. If they don't come on then you have an issue. I was told if the ambient air temp is modest and you have a free run to the dealer with no stops of any significance airflow over the rad when driving is okay to get it back. It worked.
Second win was that I finally found a use for the fairly useless Air/Con!
