5 members (DavidR, JMcL, Strathaven, BLUE+4, Soleng), 220 guests, and 35 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,611
Page 3 of 3 1 2 3
Originally Posted by AncientMariner
<snip> I remember that there was a tiny bit of rubber on the <left injector> brass barb when I got the hose off for the frame brace installation.<snip>
You know that sage advice that the problem is always the last thing you touched? It has a great track record. However, there are exceptions. I was so fixated on the notion that the hose feeding the left injector had to be the leaker, that even after renewing that hose, I wasn’t considering leakage from anywhere else. At that point, a non-mechanically-inclined friend suggested tying strips of cloth at the hose ends to confirm the source. An embarrassingly good suggestion. Lo, as HalfFull mentioned, it was the hose running athwartship between the injectors, which I had not touched, that was intermittently leaking… at both ends. A little squeezing solved it.
I don’t share the distrust that some have expressed about the crimp hose clamps. My old VW bug used them without a problem and I found them on the fuel tank connections of my 35 yr old pickup truck. Granted, the injector system runs at considerably higher pressure than my examples. I do think that after a period of usage, re-crimping to compensate for some initial creep or set in the rubber tubing couldn’t hurt.
John, retired Marine Engineer
87 Morgan +8+, 12 Morgan 3W
[quote=AncientMariner]<snip> I
A VW bug didn't have 60psi of fuel pressure.
For the sake of $5 worth of tried and trusted clamps I would change them and be done with it.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
That sounds like good advice 👍. Why bodge it when you can fix it?
well with mine it wasn't just clamps! the rubber of the hose was denaturing. splitting cracking. the gas was coming through the hose. Morgan used poor quality hoses.
I had to replace all the hoses (meaning the one between the towers too) and I learned the hard way that the hoses have to be "fuel injector" (thicker) 5/8 hoses.....with the proper clamps as planenut says.
end user
Get Morgan Customs fuel system.
yes on the list
end user
yes on the list
Move fast. Emil is selling off his remaining stock. I just got and fitted mine, and have the oil cooler still to fit.
2020 M3W
Page 3 of 3 1 2 3
