Topics49,844
Posts837,361
Posts: 38 |
I have a 2015 with chassis cracks on both sides now
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
I have a 2015 with chassis cracks on both sides now And we thought these problems stopped at the 2014 model....
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I have a 2015 with chassis cracks on both sides now And we thought these problems stopped at the 2014 model.... It would be interesting to know how many of the cracked ones are using the factory stanard shocks.
Posts: 38 |
Mine are which are going to be replaced promptly. Unfortunately I'm out of warranty and looking into options. Has anyone successfully repaired without replacing the entire chassis?
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
Chad Is your chassis one of the original ones which should have the bolt-in brace retro-fitted or it is the later design with the definitive welded in brace? (the excellent buyers guide has pictures https://www.mtwc.co.uk/wp-content/uploads/2020/07/Final-150.pdf) Where are your cracks on both sides?
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Mine are which are going to be replaced promptly. Unfortunately I'm out of warranty and looking into options. Has anyone successfully repaired without replacing the entire chassis? First contact the factory and see what they say about whether they will fix it for you.
Red Leader
Posts: 38 |
Mine are which are going to be replaced promptly. Unfortunately I'm out of warranty and looking into options. Has anyone successfully repaired without replacing the entire chassis? First contact the factory and see what they say about whether they will fix it for you. I'm in the US and Morgan West is backed up for literally 2 years
Posts: 38 |
They're on the bottom, on the vertical support that connects to the wish bone brackets. It has the old style wishbone brackets. I'm going to get some pictures up in a day or two as I can
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
They're on the bottom, on the vertical support that connects to the wish bone brackets. It has the old style wishbone brackets. I'm going to get some pictures up in a day or two as I can Check out Phil Bleazey's REPAIRThe 2014 chassis cars are much stronger than the early ones so I would hazard a guess that yours may be an early chassis car that wasn't registered until 2015 (for some reason).
Andy
Mine are which are going to be replaced promptly. Unfortunately I'm out of warranty and looking into options. Has anyone successfully repaired without replacing the entire chassis? First contact the factory and see what they say about whether they will fix it for you. I'm in the US and Morgan West is backed up for literally 2 years What, fixing M3W'ers - that can't be right.....
