0 members (), 286 guests, and 19 robots.
+8Rich 94
Posts837,276
Page 4 of 7 1 2 3 4 5 6 7
I have a 2015 with chassis cracks on both sides now
And we thought these problems stopped at the 2014 model....
It would be interesting to know how many of the cracked ones are using the factory stanard shocks.
Mine are which are going to be replaced promptly. Unfortunately I'm out of warranty and looking into options. Has anyone successfully repaired without replacing the entire chassis?
JMD Offline
Chad
Is your chassis one of the original ones which should have the bolt-in brace retro-fitted or it is the later design with the definitive welded in brace? (the excellent buyers guide has pictures https://www.mtwc.co.uk/wp-content/uploads/2020/07/Final-150.pdf)
Where are your cracks on both sides?
First contact the factory and see what they say about whether they will fix it for you.
Red Leader drive
I'm in the US and Morgan West is backed up for literally 2 years
JMD #719026 23/09/21 01:39 PM
Originally Posted by JMD
Chad
They're on the bottom, on the vertical support that connects to the wish bone brackets. It has the old style wishbone brackets. I'm going to get some pictures up in a day or two as I can
Chad
Check out Phil Bleazey's REPAIR
The 2014 chassis cars are much stronger than the early ones so I would hazard a guess that yours may be an early chassis car that wasn't registered until 2015 (for some reason).
Andy
What, fixing M3W'ers - that can't be right.....
