1 members (moggin),
219
65
Topics49,861
Posts837,542
Posts: 213 |
How do you get to advanced?
2005 Roadster 2013 M3W MOG South
Posts: 38 |
Mine was the same. ECU is fried and will need replacing. When hooked up to the diagnostics all sorts of fault codes, running rich, running lean too high a voltage etc. The give-away that the ECU was no longer with us was the voltage readings. Could be something else but that is what happened to mine
Karl
Wine For My Men...We Ride At Dawn
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Mine always lights but not problem.
Posts: 38 |
Mine always lights but not problem. Mine occasionally flashed on and I carried on driving. Coming back along the M6 from Birmingham it came on when I started to gun it to overtake. There was a loss of power then surged forward. It stayed on and all seemed normal. Yours could be a loose connection to the ECU though
Karl
Posts: 215 |
you can have this issue with a wrong working lambda sensor
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
Hi I may be a bit late but here is the way(s) that you can switch between Basic and Advanced User levels in the ProTune 2 software SUMMARY: There are two ways to change the user level setting of the software… 1) Using the menu bar: Select Select User Level… from the Options menu. 2) Using the keyboard: Hold Ctrl + press G.
hope this helps
nigel
Posts: 125 Likes: 3
Posts: 125 Likes: 3 |
Resurrecting this thread to see if any current links to the diagnostic software are known as links above give page not found when followed.
Have found the cable port so just need software to try and move forward.
Hoping someone can help, thanks in advance.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Don’t drop those cover screws!
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
You should be able to download the Protune 2 software from here: https://www.sscycle.com/flat-track/support
Posts: 125 Likes: 3
You are not kidding about those cover screws! But so far still have two....
So thanks for the link, all good. My error code is p0170 front adaptive max limit. My knowledge here gets limited but I think(!) this is to do with engine knock control.
In the Morgan which cylinder is the front? Left or right?
From previous posts I wonder if in advanced mode a reset of the adaptive maps would help? Not going there unless totally confident though!
Any thoughts?
