7 members (Simon, GRB, WR142LLJPN, Steve3.9+8, Alistair, MartO, esse16), 281 guests, and 88 robots.
+8Rich 76
DaveW 52
Topics49,868
Posts837,636
Moggo
Page 8 of 8 1 2 3 4 5 6 7 8
Originally Posted by TBM
Went over this afternoon and picked the old girl up.
As well as the gearbox conversion I also had a lighter flywheel (5.9kg compared to 9.9kg original) put in, and a quickshift fitted.
Gears took a bit of getting used to as the gate is very tight. To begin with I had lots of missed/wrong gears, but about halfway through the journey I started to get the hang of it, and she loosened up a bit so was getting the right gear every time.
The 5th gear is great - at 3400rpm I'm now hitting 80mph as opposed to 65mph (GPS Speed). With the lighter flywheel she spins up much faster, but still idles nicely and handles traffic well (Northampton was crawling speed through roadworks and traffic lights). Could easily pull away from about 20mph in 5th.
Very happy with all the work that's been done, and the resulting improvements on performance and drivability (Big thank you to Simon).
Only issue is the speedo - she's now over-reading by about 40% rather than 10%! Hopefully we may be able sort it with speedo drive changes or worst case, a speedo recalibration.
Glad you liked it!
as I said, I wasn’t wholly happy with the gear change
I’ll get a stock lever ordered up tomorrow, and we’ll see if that improves matters
I think with the quick shift, and the shortened lever to fit, and the crank on the lever, it all kind of mucks up the geometry of the shift
My old Capri was delicious to run up and down the box- but they may be tinted by 30 years of fond memories…..
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
TBM Offline OP
Originally Posted by SimonH
Glad you liked it!
Cheers Simon, it certainly freed up a lot on the journey, but I think you're right about the geometry being a bit off.
I've dropped Mike P an email to see if he had a similar problem with the speedo, and also dipped a toe in the water with speedycables to see how much a recalibration costs. Did the box come with a speedo drive? I'll email Burton and see what specs they provided.
Glad you liked it!
The box has whatever drive Burtons put in when they recon’d it
It wasn’t something we sourced…
I’d stick some tape on the speedo at 30, 50 and 70 GPS in the meantime…
It’s how we ran the pit limit on the Britcar 24hr roadster I built….
Simon @ Sifab.co.uk
TBM Offline OP
Glad you liked it!
Emailed Burton, so will see what they say - hopefully can get close with a different gear drive. If not, found that JDO should be able to recalibrate without breaking the bank.
I got Speedograph in Nottingham to re-calibrate a vintage Smiths tacho I acquired. This involved an increasing gearbox mid cable and a custom dial. Sorting your speedo drive would be a simple task for them I imagine.
The old 4 speed gearbox speedo drive would have fitted, all you need to do is make up a retaining clip for it
I think I reprofiled the existing clip and used a nearby bolt hole to secure it to the gearbox. That's what I did on my conversion
Checking the gearbox speedo gears is easy by removing the pressed in domed cover, changing it is a pain in the arse as the tail casing needs to come off. So re calibration is probably your best bet
I've got the standard gear lever, much shortened but not bent or anything. Had no issues with it but having said that it was from a fairly low mileage car - less than 30K miles.
Never really got on with quick shifts even in my rally cars, it seemed to me that they could be a bit too precise at times
Arwyn
TBM Offline OP
Cheers - Simon and I are looking at options - I've asked Burton Power what was in the box they supplied- their very helpful answer was 'whatever was in the donor box' so could be anything as it was an outright purchase.....
Had a chat with Mike P last night and according to his instructions I need a 7T worm and a 24T drive. Apparently the 7T is the most common of the worm drive so fingers crossed I have one of those in, and just need to swap the speedo drive. I have a spare 25T one at home and will check to see what is in the old 4 speed box this afternoon. Knowing my luck I have an 8T worm, but I reckon it can be swapped out with having to remove the engine/box - just the interior.
Recalibration is an option, but 40% may be a little out of range, and I have read that is only alters the speedo needle and not the odometer which is the bit I use most. That could be a bit of internet bs though!
We're also going to experiment with a standard shifter - the quick shift gate is tiny and although I was doing OK with it, I think if I was trying to shift gears in a panic, I may struggle.
When I converted my 4 speed to the T9 5speed gearbox the speedometer was way out and couldn't get it to read correctly, so I bought a plugin GPS speedometer for $30 and use that - much more accurate.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
TBM Offline OP
Forgot to say, the other delight is I now have reverse lights that work when I put the car in reverse (as opposed to a manual switch)..
Small pleasures.....
