0 members (), 314 guests, and 94 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Moggo
#683752 17/01/21 11:36 PM
O
OhioM3W Offline OP
O
So I was changing the oil and next to the filter i discover a wire hanging down after I changed the oil filter. Everything looks to be in order - nothing exposed - but this thing is hanging. I can push it in to a nut just outside the filter but it doesn’t feel right. And it’s not threaded. Any thoughts? Can’t figure out how to post a photo small enough to share 😩
OhioM3W #683755 17/01/21 11:49 PM
Post your question on Facebook on the Thre Wheeler forum, photos are waaaaay more easy.
OhioM3W #683776 18/01/21 09:28 AM
The wire could be the oil pressure sensor wire as it is next to the filter. In the photo (this isn't quite like the standard set up as it has a sandwich plate) the pressure switch is the silver and black item at about 4 o'clock in relation to the filter housing, with a wire going to it. If it is disconnected the oil pressure light will not operate correctly. For info there is a section on posting photos in the "Welcome Forum" at the top
OhioM3W #683784 18/01/21 09:48 AM
I would think it is the oil pressure switch, i broke mine when changing the filter
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
OhioM3W #683800 18/01/21 10:50 AM
O
O
That's why i switched over to using the KN-171B filter listed in Planenuts alternative parts list as it has a nut on the end so removing is easy.
OhioM3W #683801 18/01/21 11:31 AM
O
OhioM3W Offline OP
O
Thanks. That’s definitely it. It looks like everything is hooked up correctly but the whole steep just needs a place to live, and I must have knocked it off while changing the oil filter like Hugo. I think even taping it would work. Hugo?
OhioM3W #683816 18/01/21 12:31 PM
I had to replace the oil pressure switch as the nut had snapped off and the spring had come out swear
OhioM3W #683835 18/01/21 01:16 PM
I relocated the oil pressure switch by putting in a grease gun flex line and then mounting the switch to the frame members. It gave more room around the filter and it also allowed for an oil pressure gauge sender to be installed.
This was my crude test to see how well it worked with the massive oil pressure sender that came with my gauge. I need to find a smaller sender.
OhioM3W #721596 14/10/21 10:06 PM
Will the engine start with the oil pressure switch disconnected?
LightSpeed #721598 14/10/21 11:23 PM
It should do.
