2 members (Stephen888, nick w), 224 guests, and 81 robots.
+8Rich 78
Topics49,871
Posts837,679
Rudolf
Page 3 of 3 1 2 3
Image #721631 15/10/21 02:04 PM
Image Offline OP
Sorry, my op wording was imprecise ... meant that I was ready to go for a trundle once the clutch was persuaded to disengage.
It's now freed courtesy of Andrew's 'remove all cable slack' and Luddite's 'jack it up and provoke it' methods.
Have posted a short clip of it in the yard on the "Have you driven...." thread.
Many thanks for all the input.
Image #721640 15/10/21 03:13 PM
TBM Offline
Here we go. There's about 1/3 inch travel before clutch starts engaging
Clutch pedal depressed
Clutch pedal out
Showing linkage
Image #721642 15/10/21 03:24 PM
Image Offline OP
Excellent TBM .... lever looks to be in the same place as mine .... and now I know the movement I'm aiming for.
I'll have a juggle with the various adjustments until I find a good fit between pedal position and lever movement .... many thanks!
Deejay #721646 15/10/21 04:17 PM
Originally Posted by Deejay
Sorry to contradict but if the clutch plate is stuck to the flywheel, you would not even get it into gear with the engine running.
No contradiction chum, should you re-read my contribution I suggested warming the engine up first till it is running well as opposed to on the choke and fluffing about.... With it warm shut it down and jack the rear wheels clear of the deck, once well supported START IT UP IN GEAR, as the rear wheels will be free to run... and then with a bit of deft heel and toe action. throttle brake, with enough momentum built up, jumping on the brakes should break the bond between the driven plate and that which it is currently mating with and if one is adept at heel and toe the engine will not even stall..
Best to be sure that the car is not pointing at anything solid should you be overly heavy handed and cause the old thing to launch it`s self off the supports and head off into the scenery...?
I think I wrote this up on GoMoG many years ago as many laid up Morgan`s were suffering and to date no one I know of has come..err... unstuck, while un sticking their clutch..?
Luddite #721758 17/10/21 07:03 AM
I used to drive the 4/4 down the road at 10 mph or so, clutch depressed and punch the brake pedal hard.
Neighbours probably wondered what was going on grin2
Page 3 of 3 1 2 3
