1 members (Graham, G4FUJ),
280
38
Topics48,338
Posts812,939
Members9,203
Posts: 32 |
Toucan 1981 4/4 Kent
Posts: 2,062 Likes: 57
Posts: 2,062 Likes: 57 |
René I am afraid that the tooltray will not fit to your car.....
Posts: 1,024 Likes: 15
Posts: 1,024 Likes: 15 |
Hello bmgermany,
no problem - part which doesn't fit will be eaten ;-)
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
About one year ago I change my hexagon wheelnuts over to twoeared spinners. Undo the nuts with the MWS brass spinner was a easy job, but now I undo the twoeared spinners for the German MOT. Very frustrating. Undo the spinners with the soft hideside doesn‘t work. Undo the spinners with the Copperfield work, but now there are some dents at the spinners, also a little damaged. I think I now change over to the THOR nylonhammer. This one… https://www.limora.com/de/schonhammer-159585.htmlGreets René
Posts: 5,107 Likes: 56
Black Rat Charter Member
Posts: 5,107 Likes: 56 |
Why not get one of Lionel's 2 eared billet spanners ? you need a breaker bar as well but no more dented or stuck on spinners.
Posts: 2,222 Likes: 20
Posts: 2,222 Likes: 20 |
Craig Jezz
Posts: 7,918 Likes: 216
Posts: 7,918 Likes: 216 |
Just ordered one myself - £55 all in. Excellent service from Lionel Roberts 07947 712427.
Posts: 1,576 Likes: 103
Posts: 1,576 Likes: 103 |
About one year ago I change my hexagon wheelnuts over to twoeared spinners. Undo the nuts with the MWS brass spinner was a easy job, but now I undo the twoeared spinners for the German MOT. Very frustrating. Undo the spinners with the soft hideside doesn‘t work. Undo the spinners with the Copperfield work, but now there are some dents at the spinners, also a little damaged. I think I now change over to the THOR nylonhammer. This one… https://www.limora.com/de/schonhammer-159585.htmlGreets René You are still using the wrong hammer. Correct one to use is actually a lead mallet - lead being softer than both brass and copper. No need for fancy sockets and the like when you have the right tool in the first place Arwyn
About one year ago I change my hexagon wheelnuts over to twoeared spinners. Undo the nuts with the MWS brass spinner was a easy job, but now I undo the twoeared spinners for the German MOT. Very frustrating. Undo the spinners with the soft hideside doesn‘t work. Undo the spinners with the Copperfield work, but now there are some dents at the spinners, also a little damaged. I think I now change over to the THOR nylonhammer. This one… https://www.limora.com/de/schonhammer-159585.htmlGreets René You are still using the wrong hammer. Correct one to use is actually a lead mallet - lead being softer than both brass and copper. No need for fancy sockets and the like when you have the right tool in the first place Arwyn Fancy sockets have got to be better than whacking it!
Craig Jezz
Posts: 11,854 Likes: 137
Posts: 11,854 Likes: 137 |
It does however seem to me to defeat the whole purpose of having eared spinners in the first place. They were specifically designed to be hit with a hammer to enable fast wheel changes. If one prefers to use a socket wrench to avoid damage, a perfectly reasonable thing to want to do, then why not use the fasteners specifically designed for the job?
