4 members (Morganmike, bmgermany, Ian Wegg, John Winn), 309 guests, and 87 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#721798 17/10/21 02:52 PM
NickB54 Offline OP
Has anyone had an issue with their headlamp surround on a Plus Six? Mine don’t fit well and appear to have a random M5 nut used as a spacer on the retaining screw, between the surround and the plastic mounting.
Yes headlamp chrome surrounds are a big problem at Morgan. The current bodge to fix it and stop them being a poor fit is to glue some cork spacers inside the surrounds at the bottom so when the one retaining ring screw is fitted (at about '5 o clock position)it tightens onto the cork and does not 'lift' the chrome surrounds off of the two top lugs...
Lets face it these are a poor 'lucas legacy' design....
Triumph Herald 1969 13/60
Morris 1970
NickB54 Offline OP
Thanks for the update, do you know if Morgan have a fix?
Yes it's a random M5 nut innocent
Seriously though you are probably better off finding a custom solution yourself. Rob's suggestion with cork spacer and the "standard" factory (5") strip of self adhesive neoprene stuck over top of headlamp retainer as a starter.
Neoprene works well
Neoprene can fix most things.
Soft spacer? Neoprene
A post finisher? Neoprene
Stop a leak? Neoprene
Stop rattles? Neoprene
Neoprene is what I use...it also reduces the wind noise and whistle through the headlight
Morris 1970
And it comes with a self adhesive strip if you use draught excluder
NickB54 Offline OP
Thanks guys, I’ll put up with a lot on my Morgan and consider many of the idiosyncrasies as part of the vehicle’s characteristics, however a bodge is a hodge and this is a hodge and, in my humble opinion not acceptable on a new car. Wish me luck at Morgan Works Malvern
They will call it a feature.
