0 members (), 311 guests, and 40 robots.
John V6 68
DaveW 64
+8Rich 62
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,075
Captain Morgan, IRWIN
If the car has a brake servo make sure the servo has not failed ie clamp the vacuum pipe to the servo.
David Byrne
When you come to re-tune your Weber you may find this useful:
https://www.racetep.com/weberadj.html
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
RobFog Offline OP
Just wanted to update the status of this problem, just in case somebody else draws a blank with all the great suggestions and links that were provided.
It turns out that the arm that connects the throttle mechanism to the weber was slightly out of alignment - moving this back to the intended alignment solved the problem .
Indicated here [img]https://photos.app.goo.gl/r63dAmQd2JST5zYP6[/img]
As always, I'm very much a newbie on all things mechanical and your patience and encouragement provide a huge motivation for me. I probably would have thrown in the oily rag at this point if it wasn't for your help
1974 4/4 2 seater
Well done in solving the issue, most times the revs running high is something in the throttle mechanism sticking, etc. You may want to check that the return springs are still strong and working correctly as they keep things tight and stop erratic movement, the best set up is two springs one inside the other.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
RobFog Offline OP
Thanks, great suggestion, the current ones are looking a little old, I'll add those to my next order .
1974 4/4 2 seater
RobFog Offline OP
A quick follow-up question - is there a specific need for a Morgan type spring or would any general spring approximate to being reliable for the job
I found these on Amazon "Spectre Performance 4700 Throttle Return Spring"
1974 4/4 2 seater
TBM Offline
Any will do - I used these
MGB Throttle Spring
Have had the same problem on our 73 4/4. That little bracket is a poor design. The problem creeps up every few years. I really need to design a better piece to fix it permanently .
1973 4/4 "Henry A"
1953 +4 Flat Rad "Pug"
1984 Citoen 2CV Special "BeBe"
https://morgan34.org/
TBM Offline
Like the look of this kit. Linkage Kit
Might knock up something similar.
Yes, that is much better!
1973 4/4 "Henry A"
