Morgan Aero 8
0 members (), 332 guests, and 25 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
Originally Posted by SimonH
Originally Posted by NickCW
Is the problem that the OE part isn't available from whoever supplied them (Ford/Land Rover etc) or is it that we don't know what it came from?
I know what the originals were from..
I've spent the last 12 months trying to source them.
They are no longer available anywhere.
I have an aftermarket motor and cable solution that will be able to be fitted and will work, but its not quite a like for like fit- hence why I need a car to prototype on....
I'm not MMC- I don't just guess how parts will fit... hide
What were they from out of curiosity?
Aero 8 GTN #11
when my passenger one went, snapped cable as it had corroded with lack of use, it was a Fiesta unit but I think a bespoke set of bowden cables wound on to it or modified originals. Splined Hub in Oundle did mine a few years back.
I'm yet another owner looking for a window motor for an Aero S1 on drivers side. Have emailed Simon of SiFab to see if he had any success? sherlock
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2012 +4 Supersport - past
2008 Aero S4 -past
Let me know if you have any luck as I’m still looking for one 18 months later😁
Will do, Simon from SiFab is still working on a replacement. Is window not working an MOT failure?
Cheers
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2008 Aero S4 -past
PJC Offline
An electric window not working is NOT and MOT failure - just an annoyance, particularly in relation to the sound of the side exit exhausts!
Cheers, Paul
I think when the factory replaced mine in the S1 over 5 years ago the unit was £750 !!!!
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Remove the plasic shroud think its four screws have a look inside if your not confident a good auto electrician the type that recon starters and altenators will fix it for you even if you buy a similar motor and switch the innards. The bowden cables can be bought at various length from any motorbike shop. If you run a series 1 you have to dig about a bit the factory is no help at all and the other guys who sell some spares wont tell you what they came off....
Hi all ,
If you are looking for the motor only i have some used one.s that came with the car when i bought it.
Unfortunately i don' t Know where he sources there but i confirm there are original when i have repaired my mechanism!
Pm for more or pics
Regards
We don’t tell you what the parts are from because 90% of the time they are modified from OE
And also our knowledge is hard won, I for example have 22 years experience with Morgan and if we disappear, and the factory are no hope- where does that leave you as the owners?
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
