Morgan Aero 8
6 members (OZ 4/4, DickJ, Mark+4, +8Rich, Trim, CooperMan), 296 guests, and 28 robots.
John V6 66
DaveW 64
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Topics48,349
Posts813,100
Members9,212
aeroed, DJC, James Mc, JimWhin
Originally Posted by SimonH
Originally Posted by NickCW
Is the problem that the OE part isn't available from whoever supplied them (Ford/Land Rover etc) or is it that we don't know what it came from?
I know what the originals were from..
I've spent the last 12 months trying to source them.
They are no longer available anywhere.
I have an aftermarket motor and cable solution that will be able to be fitted and will work, but its not quite a like for like fit- hence why I need a car to prototype on....
I'm not MMC- I don't just guess how parts will fit... hide
What were they from out of curiosity?
Aero 8 GTN #11
when my passenger one went, snapped cable as it had corroded with lack of use, it was a Fiesta unit but I think a bespoke set of bowden cables wound on to it or modified originals. Splined Hub in Oundle did mine a few years back.
I'm yet another owner looking for a window motor for an Aero S1 on drivers side. Have emailed Simon of SiFab to see if he had any success? sherlock
AnDrew G
2003 Aero S1
2009 Aeromax - past
Let me know if you have any luck as I’m still looking for one 18 months later😁
Will do, Simon from SiFab is still working on a replacement. Is window not working an MOT failure?
Cheers
AnDrew G
2003 Aero S1
2009 Aeromax - past
PJC Offline
An electric window not working is NOT and MOT failure - just an annoyance, particularly in relation to the sound of the side exit exhausts!
Cheers, Paul
I think when the factory replaced mine in the S1 over 5 years ago the unit was £750 !!!!
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Remove the plasic shroud think its four screws have a look inside if your not confident a good auto electrician the type that recon starters and altenators will fix it for you even if you buy a similar motor and switch the innards. The bowden cables can be bought at various length from any motorbike shop. If you run a series 1 you have to dig about a bit the factory is no help at all and the other guys who sell some spares wont tell you what they came off....
Hi all ,
If you are looking for the motor only i have some used one.s that came with the car when i bought it.
Unfortunately i don' t Know where he sources there but i confirm there are original when i have repaired my mechanism!
Pm for more or pics
Regards
We don’t tell you what the parts are from because 90% of the time they are modified from OE
And also our knowledge is hard won, I for example have 22 years experience with Morgan and if we disappear, and the factory are no hope- where does that leave you as the owners?
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
