2 members (Black Adder, Luddite), 210 guests, and 26 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,037
#722625 25/10/21 11:46 PM
Does anyone know what would be involved with changing from British right side drive to left side drive? For instance can you use the same steering rack flipped over? The rest looks fairly ambidextrous in the M3W. Most if not all tabs or brackets should be there. Any thoughts?
If you flip the rack over, the car would go right when the steering wheel turns left and vice versa. Unless you moved the steering arms to the front of the upright, but that's not really practical as the rack would also need to go forward. So that's a no go.
Late 2012 M3W
Toys for Boys
Toys for Boys
Not sure about the USA, but in Europe the Certificate of conformity and hence the registration document is different for LHD & RHD M3W’s. Having said that it’s not a difficult job as, as you say, the chassis is built to accommodate both options. Whether you can get the required parts out of Morgan is another issue. You main parts you need are a new steering rack, new dash board backing, new dash panels but pretty much everything swaps over from memory. I left the handbrake in the same place as I didn’t want to mess with the upholstery, you can chose whether you want to change the steering column cowl etc. By looking at the parts book you can see the LHD v RHD specific parts.
Omne trium perfectum
Thanks guys.
Lots of fun driving a RHD on LHD roads!!!. Especially a Morgan....
'34 Family 4
'70 +8
'03 Hummer H2
Easy job only need some specifics parts
I Had seen by the past for doing it
Not so expensif
