Old Book
Topics49,940
Posts838,605
Posts: 22,386 Likes: 359
Posts: 22,386 Likes: 359 |
Nice job TBM. Working metal is probably the most satisfying part of fettling.
Posts: 5,473 Likes: 173
Posts: 5,473 Likes: 173 |
That looks very good. Well done.
Posts: 12,285 Likes: 329
Posts: 12,285 Likes: 329 |
That looks very good. Well done. +1, nice job!
Posts: 8,728 Likes: 514
Posts: 8,728 Likes: 514 |
That looks very good. Well done. +1, nice job! Yes, very good, did you have to anneal it again half way through bashing ?
Posts: 37,499 Likes: 996
Posts: 37,499 Likes: 996 |
Nice one TBM, the last time I had a ball pein hammer in my hand was making a copper pin tray at school in metalwork classes, I loved them. My stepmother still has it with the wooden fruitbowl I turned in the woodwork class.
Posts: 988 Likes: 14
Posts: 988 Likes: 14 |
Nice one TBM, the last time I had a ball pein hammer in my hand was making a copper pin tray at school in metalwork classes, I loved them. My stepmother still has it with the wooden fruitbowl I turned in the woodwork class. [Pedant mode] Having also made a copper trinket tray at school metalwork, they should have given you a planishing hammer [/Pedant Mode] Lovely job TBM
Brian
Jersey and Spain
Nice one TBM, the last time I had a ball pein hammer in my hand was making a copper pin tray at school in metalwork classes, I loved them. My stepmother still has it with the wooden fruitbowl I turned in the woodwork class. [Pedant mode] Having also made a copper trinket tray at school metalwork, they should have given you a planishing hammer [/Pedant Mode] It probably was it was 58 years ago now  and on a good day I can remember my wifes name well it's 51 years ago tonight that we met so just as well I can..
I made my own Repousse hammer at college...and still have it, whilst training to be a Silversmith
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
Had to cut a hole in my gearbox tunnel to access the angle drive. Made this little plate to cover the hole and give some space for the drive. Not done anything like this before so pleased with the result. Used a ballpein and a wheel spacer. ![[Linked Image]](https://tm-img.com/images/2021/10/31/IMG_20211031_102412.jpg) looks like something I might buy at a craft fair, very attractive
Kevin
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
I was getting irritated by the SATNAV mounted on the windscreen because wherever I put it that I could see it easily it would partially obscure the view of the road, especially curbs and corners at night down country lanes. I didn't want to make any extra holes in the dash so I used a bit of scrap aluminium bar, bent it to roughly the contour of the dash, removed the tonneau cover stud (which I never use) and fixed the aly strip using a slightly longer bolt. The strip went under the rear view mirror which acts as an additional securing plate. I found a self adhesive ball mount on eBay for a fiver which is metal rather than the plastic one that came with the Garmin. It's stayed fixed in place for several days now so looks like the adhesive on the ball mount is plenty strong enough. I now have unobstructed vision through the windscreen and can see the SATNAV easily, Although it doesn't look like it in the photos I can see all of the instruments easily. Five quid and an hour of my time (could have been less but I buffed the aly strip) and I'm very happy with the result. ![[Linked Image]](https://www.tm-img.com/images/2021/11/03/Satnav.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/11/03/Satnav-mount.md.jpg)
Steve L.
1996 Plus 8 N22 MOG
