0 members (), 311 guests, and 33 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#72367 06/11/11 08:54 AM
booty Offline OP
during a recent trip i seem to have lost all side lights and instrument lights as well as front fog as all these things seem to be on different fuses dont think it can be this ...help
booty #72376 06/11/11 09:29 AM
booty Offline OP
fuses seem to be ok so why side lights front fog and panel lights
booty #72381 06/11/11 10:30 AM
Which model and year is it?
1972 4/4 2 Seater
tmg513 #72385 06/11/11 11:08 AM
booty Offline OP
2000 *4
booty #72388 06/11/11 11:29 AM
http://www.gomog.com/allmorgan/4~4%20Diagram%20for%20Morgan%20Dash%201800%20Focus.pdf
Assuming this is the correct wiring diagram and that the same fault is causing both problems: all of the instruments are fed from the same wire (green) that goes back into the loom at the top of the diagram. You'll need to trace this back to the fuse. Then test for power at every connection until you find the problem.
1972 4/4 2 Seater
tmg513 #72554 07/11/11 06:58 PM
booty Offline OP
Are the only fuses the ones under the dash?
booty #72605 08/11/11 07:12 AM
They vary, do you want to bring it around at the weekend and we could take a look together? (Part of my lighting circuit is in bits at present...).
Cheers,
booty Offline OP
Graham thank you for your kind offer I would love to bring it around and pick your brains if you let me know when it would be convenient
Regards. Andrew
booty #73112 12/11/11 11:32 AM
Hi Andrew,
I'm not planning on going anywhere.
Waiting on a builder to come take a look at some work, so should be in over the weekend.
I'll PM the address / phone.
Cheers,
I've emailed New Elms, but the plot thickens a little.
No dash or sidelights (both front/rear each side) at all.
I don't know where the front auxilliary lamps are powered from, but I suspect via the sidelamp circuit.
Main beam if I remember correctly is pull on, pull off on the dip / indicator stalk - i.e. a latching relay. But main is not latching, main only comes on as headlamp flash.
I suspect either the multifunction switch has failed in sidelamp, or if fitted a relay that powers sidelamps/dash lights.
However, there is one other possibility: I don't believe "dim-dip" was fitted in 2000 but may be wrong - can anyone confirm this as they are notorious for causing problems...
BTW - lovely looking +4 Andrew!
Cheers,
