Topics48,341
Posts812,981
Posts: 3 |
I am going to fit sun visors to 2015 plus 4. What are the views on fixed on, versus clip on. And who do you recommend as a supplier.
2022 Plus Four LM62
Posts: 922 |
Hi John, I don't want to put you off as there are multiple reasons for having visors, I'm also wary of raining on anyones parade so here goes. I have sun visors and found that the best way to manage low sun is a peaked cap. Depending on which fixings you choose, a cap saves the inevitable frustration at them drooping down all the time
Kevin
Posts: 172 |
We have fitted a green graduated sun strip - well it is a 1980's car.....
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 7,894 Likes: 241
Posts: 7,894 Likes: 241 |
I've got a graduated vinyl strip, sun visors & a hat  John, your 2015 car should have threaded sockets on the upper frame, spaced to take factory visors, they are available from dealers as an accessory
Posts: 1,560 Likes: 7
Posts: 1,560 Likes: 7 |
My windscreen doesn’t have visor fixings so I bought some clip-ons. The problem I found was that with the hood up there was a small gap around the fixings and rain seeped through quite badly, after a while I stopped using them and replaced the foam sealing strip on the hood header rail.
Steve L.
1996 Plus 8 N22 MOG
Posts: 5,108 Likes: 56
Black Rat Charter Member
Posts: 5,108 Likes: 56 |
If the sun is shining the roof is down and the sun is above the windscreen, the visors are useless plus the factory ones droop. Get a peaked ball cap.
Posts: 7,342 Likes: 91
Posts: 7,342 Likes: 91 |
I see it differently. I've been using factory sunvisors for a year and a half, and one frequent and important use is when the sun is above the windshield with the roof open. My sunvisors remain stable folded upwards.
Posts: 5,221 Likes: 123
Posts: 5,221 Likes: 123 |
I see it differently. I've been using factory sunvisors for a year and a half, and one frequent and important use is when the sun is above the windshield with the roof open. My sunvisors remain stable folded upwards. +1 and 7 years
