Posts837,992
Posts: 81 |
What is included in the 2020 Plus 4 tool kit? I seem to be missing a couple of items. Thanks, LarryS
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I would assume that if it has a spare wheel then the means to change the wheel, otherwise a bag of goo...
Posts: 1,360 Likes: 5
Posts: 1,360 Likes: 5 |
Hi Larry I’ll have a check in the morning and get back to you but from memory it’s pretty minimalist (defo no car jack) HB
Plus Four Bentley Velvet Red “Grandi P” Golf ehybrid thingy “Toadie” Polestar 4 “Vger”
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
I assume you mean a plus 4 (one of the last) not a plus four CX series since your post is in Classics. If I'm correct there should be a jack (and handle for same) plus hex wheel nut tool and thor hammer, assuming you didn't spec alloy wheels.
Posts: 27,835 Likes: 761
Posts: 27,835 Likes: 761 |
If the cx car it is no jack but wheel spanner sealant and pump i believe
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
I see my post went missing again. Assuming the car is located where the OP shows (in the sidebar) the new generation Plus Four (as against the earlier steel chassis Plus 4) is not available in the USA yet. I understand MMC hopes this will change in 2022.
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
I assume you mean a plus 4 (one of the last) not a plus four CX series since your post is in Classics. If I'm correct there should be a jack (and handle for same) plus hex wheel nut tool and thor hammer, assuming you didn't spec alloy wheels. Same tools with my 2011 plus 4, but the plastic tool tray has a couple of mouldings that are empty, so it may make you think that something is missing.
In the unlikely event you are talking CX rather than Trad I have taken a picture of the meagre offering….! ![[Linked Image]](https://www.tm-img.com/images/2021/11/14/CB604053-1A90-4F9A-8A35-B176E5F7DD83.jpg) HB
Posts: 215 |
In the unlikely event you are talking CX rather than Trad I have taken a picture of the meagre offering….! ![[Linked Image]](https://www.tm-img.com/images/2021/11/14/CB604053-1A90-4F9A-8A35-B176E5F7DD83.jpg) HB My traditional 2017 Plus 4 with no spare wheel came with just the top 3 of those , I understand that on the CX cars the bottom two items are to release the Auto gearbox from the park position.
I assume you mean a plus 4 (one of the last) not a plus four CX series since your post is in Classics. If I'm correct there should be a jack (and handle for same) plus hex wheel nut tool and thor hammer, assuming you didn't spec alloy wheels. Same tools with my 2011 plus 4, but the plastic tool tray has a couple of mouldings that are empty, so it may make you think that something is missing. Yes lack of first aid kit (clearly marked space) is the main missing one on UK cars.
