4 members (verysideways, Stevo666, Tony Quinn, TBM), 298 guests, and 42 robots.
+8Rich 94
John V6 49
Posts837,994
rockabilly john
LarryS Offline OP
What is included in the 2020 Plus 4 tool kit? I seem to be missing a couple of items. Thanks, LarryS
Formerly known as Aldermog
I would assume that if it has a spare wheel then the means to change the wheel, otherwise a bag of goo...
Hi Larry
I’ll have a check in the morning and get back to you but from memory it’s pretty minimalist (defo no car jack)
HB
Golf ehybrid thingy “Toadie”
Polestar 4 “Vger”
I assume you mean a plus 4 (one of the last) not a plus four CX series since your post is in Classics. If I'm correct there should be a jack (and handle for same) plus hex wheel nut tool and thor hammer, assuming you didn't spec alloy wheels.
If the cx car it is no jack but wheel spanner sealant and pump i believe
I see my post went missing again.
Assuming the car is located where the OP shows (in the sidebar) the new generation Plus Four (as against the earlier steel chassis Plus 4) is not available in the USA yet.
I understand MMC hopes this will change in 2022.
Same tools with my 2011 plus 4, but the plastic tool tray has a couple of mouldings that are empty, so it may make you think that something is missing.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
In the unlikely event you are talking CX rather than Trad I have taken a picture of the meagre offering….!
HB
Polestar 4 “Vger”
HB
My traditional 2017 Plus 4 with no spare wheel came with just the top 3 of those , I understand that on the CX cars the bottom two items are to release the Auto gearbox from the park position.
Yes lack of first aid kit (clearly marked space) is the main missing one on UK cars.
