New
Topics48,365
Posts813,389
Members9,215
Posts: 62 Likes: 1
Posts: 62 Likes: 1 |
Hi all more help please,has anybody removed the lenses on the rear valance of a late model traditional Plus 4, I have moisture inside and would like to dry them out and seal them properly.
Colin
2019 Plus-4 Royal Guardsman Blue 2020 Subaru 2.5iP 2014 Toyota Landcruiser 200 series 4.5l diesel
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
Welcome. You might be better posting this under maintenance. Remove the spare wheel. You can then remove the bulb holder .
Posts: 62 Likes: 1
Thank you JohnV6 too easy
Colin
Posts: 1,028 Likes: 15
Posts: 1,028 Likes: 15 |
I was tired about the quality of the Germany „Quality“ HELLAs and made a LUCAS conversion.
I bought the original connectors and than lined them in plug & play and reversibel.
Now (if there would be some water in) I can open them easy and dry. And as a point of safety: often drivers behind me don‘t notice the light, which shines very dark too.
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 7,944 Likes: 218
Posts: 7,944 Likes: 218 |
For the benefit of others the integral to rear valance, Hella style fog and reversing lights are accessed from inside the rear panel after removing spare wheel. The inner part of lamp is on a bayonet so can be removed for bulb access by turning anti-clockwise about 30° as viewed from inside. There is a rubber seal which may benefit from a little vaseline on re-fitting although I've had no issues with water ingress. Ref René's comment above, an upgrade to LED replacements will give much brighter rear lights or you can have double reverse or fog lights (loom wiring already present) as per this thread although involving a lot more work.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
My 2012 reversing light half filled with water, but nothing in my 2016.
Colin, make sure the rubber boot point downwards on refitting
