0 members (), 202 guests, and 77 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
Page 3 of 6 1 2 3 4 5 6
TBM Offline
Originally Posted by SimonH
Originally Posted by TBM
I orginally thought about making my own, but considered the £45 cost for a stainless pair suprisingly good value (especially for a Morgan part).
£45!
Mine are £38
Loads of sets on the shelf….
You need a website smile Or at least an online stock/price list....
Tried to call today about the gearbox, will call next week when you're back. Cheers.
Gordon D,
Many thanks for the offer to measure, I found the drawing I was looking for on GoMog.
Regards
Jack
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
X
xc68anc Offline OP
X
In cause the worries about the clutch (just waiting for the cylinder) I think: great time to fit the BRBs.
Working striktly as the „manual“ said and looking forward to an 1/2 hour job. After a few minutes: yes, I must drill holes.
And the next point: if I fix the BRB under the kingpinbolt on top of the washers… surprise, surprise… the lower end is about 1/2“
(Inch, not centimeter) away from the chassis.
Switch off the light, close the garage. Next step on monday.
Greets René
2018 plus4 (sports green)
Yes mine too. I just pressed it down to mark the drill location and when drilled used the bolt to bring the bar into position. There is somewhere on the forum a note about marking the location with the bar slightly loose on it's top mounting and firming it up once drilled
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
X
xc68anc Offline OP
X
One of my friends was an engineer, he told me: never fit parts under torsion. This will cause a damage. So I think I‘ll do little metalwork for a better fit.
Greets René
And: German „overdone“?
https://www.schmitt-bcs.de/morgan_vorderachsstabi.php
[/quote]
Greets René
[/quote]
A very sound approach from your engineer friend. I learned years ago to adopt that approach too with plumbing...forcing pipes into joints is always asking for trouble.
As far as the German version of BRBs is concerned, beautiful workmanship but definitely a case of overkill. In the unfortunate event of an accident, you don’t want the front end to be TOO rigid.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
When I fitted mine the bars were hovering a bit short of the chassis .... as above, I never like to stress things into position unless there's no alternative .... packed the gap with a stainless penny washer and bolted it up as normal. Perfectly solid solution.
I was just about to ask if this was a viable solution. BRBs are on the list of forthcoming purchases, along with remote greasing system, new tyres, steering bearings...
2004 Series 1 Roadster
I did the same on my Plus 4.Spacer washers.
Some things are designed to be under tension. The cross head stays on your car for example. I understood the BRB came with bolts designed to shear in a front end crash. I can't see that small amount of tension being an issue but the washer trick will obviously eliminate it.
