1 members (Moggo),
234
70
Topics49,880
Posts837,761
Posts: 6,672 Likes: 439
Posts: 6,672 Likes: 439 |
I orginally thought about making my own, but considered the £45 cost for a stainless pair suprisingly good value (especially for a Morgan part).
£45! Mine are £38 Loads of sets on the shelf…. You need a website  Or at least an online stock/price list.... Tried to call today about the gearbox, will call next week when you're back. Cheers.
Posts: 172 |
Gordon D, Many thanks for the offer to measure, I found the drawing I was looking for on GoMog. Regards Jack
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
In cause the worries about the clutch (just waiting for the cylinder) I think: great time to fit the BRBs.
Working striktly as the „manual“ said and looking forward to an 1/2 hour job. After a few minutes: yes, I must drill holes.
And the next point: if I fix the BRB under the kingpinbolt on top of the washers… surprise, surprise… the lower end is about 1/2“ (Inch, not centimeter) away from the chassis.
Switch off the light, close the garage. Next step on monday.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
Yes mine too. I just pressed it down to mark the drill location and when drilled used the bolt to bring the bar into position. There is somewhere on the forum a note about marking the location with the bar slightly loose on it's top mounting and firming it up once drilled
Kevin
Yes mine too. I just pressed it down to mark the drill location and when drilled used the bolt to bring the bar into position. There is somewhere on the forum a note about marking the location with the bar slightly loose on it's top mounting and firming it up once drilled One of my friends was an engineer, he told me: never fit parts under torsion. This will cause a damage. So I think I‘ll do little metalwork for a better fit. Greets René And: German „overdone“? https://www.schmitt-bcs.de/morgan_vorderachsstabi.php
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
[/quote] One of my friends was an engineer, he told me: never fit parts under torsion. This will cause a damage. So I think I‘ll do little metalwork for a better fit. Greets René And: German „overdone“? https://www.schmitt-bcs.de/morgan_vorderachsstabi.php[/quote] A very sound approach from your engineer friend. I learned years ago to adopt that approach too with plumbing...forcing pipes into joints is always asking for trouble. As far as the German version of BRBs is concerned, beautiful workmanship but definitely a case of overkill. In the unfortunate event of an accident, you don’t want the front end to be TOO rigid.
Posts: 5,588 Likes: 603
Posts: 5,588 Likes: 603 |
When I fitted mine the bars were hovering a bit short of the chassis .... as above, I never like to stress things into position unless there's no alternative .... packed the gap with a stainless penny washer and bolted it up as normal. Perfectly solid solution.
Posts: 502 |
K I was just about to ask if this was a viable solution. BRBs are on the list of forthcoming purchases, along with remote greasing system, new tyres, steering bearings...
2004 Series 1 Roadster
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
K I did the same on my Plus 4.Spacer washers.
Posts: 27,822 Likes: 750
Posts: 27,822 Likes: 750 |
Some things are designed to be under tension. The cross head stays on your car for example. I understood the BRB came with bolts designed to shear in a front end crash. I can't see that small amount of tension being an issue but the washer trick will obviously eliminate it.
