Topics49,861
Posts837,540
Posts: 47 |
I wanted to help my lovely V8 breathe and the original air filter box wasn’t doing it for me. I fitted a K&N inside the box but there is little room for the air to flow so I wanted a proper open K&N arrangement.
Here is what I fabricated from a used air filter canister off eBay - not wanting to butcher my original part so I can put it all back together as original if I should want to. I cut away most of the air box but have kept part of the bottom to retain the outboard mountings. This gives extra stability by using all four original rubber mounting points. Then had a 88.9mm (3 ½”) OD pipe 1.5mm wall thickness & cut to 30mm long welded on for the K&N RG-1001 to fit.
I did not have to lift the bonnet off to remove the original filter canister which pulls up at the inboard end and pulls inwards to come off the outboard pins. A bit tight so be carful.
So what is the gain? Well, maybe a few horse power? It certainly looks much better when opening the bonnet and the intake howl when I open her up is wonderful – just like on my motorcycles which also run K&N open filters.
Images removed at request of OP
Last edited by asbojohn; 21/12/21 08:37 AM. Reason: Removed images as requested by 1340fxd
1997 +8 BRG, BMW Z4, Harley FXD, Greeves Silverstone RDS, Kawasaki H2 & Z1000 - no electric cars!
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
Nice work. Which k&N did you go for?
Posts: 47 |
The filter is K&N RG-1001 - available in other colours too
Just been looking at used air filter canisters - wow they’re not cheap are they?
Posts: 47 |
Yes, not cheap. You can of course use your existing one but then there is no going back! In addition you need to buy the 3 1/2 pipe and get it welded - about £50. It took me about one hour to do the cutting and then grind it to a good finish. Worth the time/cost - I would say so, having seen a few other variations!
Posts: 830 Likes: 23
Posts: 830 Likes: 23 |
Run K&N on the carburetted +8 for 30 years. Replaced filters a couple of times. Makes a big difference to the under bonnet space junking the original system.
1980 +8 Blue And a few others ---------------- Stephen
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Good work, it looks very nice. I‘m also in Harleys and old MINIs (and clear: I‘ve got a K&N)… beware the birds - they could be breathed in ;-)
I love the sound of fresh air to the engine.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Yes, not cheap. You can of course use your existing one but then there is no going back! In addition you need to buy the 3 1/2 pipe and get it welded - about £50. It took me about one hour to do the cutting and then grind it to a good finish. Worth the time/cost - I would say so, having seen a few other variations! I can do the fabrication and welding myself, also have a method for ‘faux powder coating’. Might have a go over the winter. Well done and thanks for the inspiration
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
Looks good I may have a crack at that- what holds the filter element on to your bracket?
99 plus 8 indigo
Posts: 47 |
The K&N RG-1001 simply pushes onto the 3 1/2" tube that's welded to the cut-down airbox and is held there by a large jubilee clip. The filter comes with three adapters to cater for different pipe o/d but 3 1/2" is the way to go when you have the short pipe welded on.
