Topics49,880
Posts837,761
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Yes, John, you‘re Right.
It looks like I‘m the only one with fitting the bar on top of the washers. And yes, in the pictures no difference.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
The BRB's help support the cross frame, in this case the upper suspension arm so it makes plain engineering sense to have that support as close as possible and in best contact with the frame. The exception is the upper shock absorber bracket which is broad and of substantial thickness to support shock loads and provide wing support, so also needs to be close to the action.
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
All the pictures I've seen have not had the tyre rubbing blocks fitted. My '74 4/4 does have these and they make the fitting of the Williams supplied BRBs significantly more difficult. The bottom fixing almost fits with the forward mounting bolt of the blocks but I had to move this inboard (re-drilling block and chassis) to avoid the tyre rubbing on the BRB. The rear mounting bolt of the damper retainer also causes a bit of grief. Both fitted now but work needed on both sides.
