3 members (+8Rich, Mr K, Grumpy2), 405 guests, and 94 robots.
Sagging Hood
Topics49,859
Posts837,483
#726322 01/12/21 06:26 PM
My new to me 2017 M3W has some leak from the brake fluid reservoir.
At the beginning I thought it is because the reservoir was over-filled. I took some of the brake fluid out and the level is now below the max mark. I also tightened the hose clamps but it still leaks.
It appears the leak is coming at the cap area. I checked the cap and it appear ok and well tightened with healthy looking rubber seal.
Any suggestions please?
I am not sure if this is of any help but the red brake warning light comes for a a few seconds when doing "hard" right-hand cornering (and fast driving in roundabouts), This red warning brake light does not come on left-hand cornering).
Thank you
Ahmed
M3W: 2017 green
Caterham: 2003 yellow
Evora 400: 2016 black
SL500: 2005 blue
HD Breakout: 2020 red
The brake warning is because the fluid level is low and you are cornering. It shouldn't be too tricky to clean everything off and see where the leak is from and fix it.
The fluid level is just a couple of millimetres below the max level. So it's not really low.
The fluid is seen dripping at the lower rim of the cap (see pic please). So possibly it is coming through the reservoir opening. ie not tight cap.
[img]https://photos.app.goo.gl/eVUiUtTiUKA33dmQ6[/img]
M3W: 2017 green
SL500: 2005 blue
Is this brake fluid leak a common thing in Morgan? (i see the plus 4 uses the same brake fluid reservoir)
M3W: 2017 green
SL500: 2005 blue
Have you checked the previous owner has not lost the sealing washer in the cap ? It's a flat black rubber washer
I don't know how it is supposed to look like but here is a pic of the inside of the cap.
[img]https://photos.app.goo.gl/wzZP5wRS5gmih5Qb9[/img]
M3W: 2017 green
SL500: 2005 blue
Make sure the tiny vent hole in the cap is not plugged so the reservoir can breathe.
Late 2012 M3W
Errmm, I don't know where the hole is confused2
M3W: 2017 green
SL500: 2005 blue
BTW, is there a better way to insert images. I looked at the "forum help" and it says the "image manager" link will allow me to navigate files on my pc and attach. This is not working with me confused2
M3W: 2017 green
SL500: 2005 blue
Follow this video for the best way to insert images into your posts.
Posting images to TM
Regards
Alan
AP08 MOG
