10 members (dogmog, Paul F, MartinB60, DJ66, CooperMan, Alistair, MJF, OZ 4/4, chanteclair, RichardV6), 249 guests, and 10 robots.
John V6 69
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,021
RedThree
Originally Posted by M3W Glasgow
BTW, is there a better way to insert images. I looked at the "forum help" and it says the "image manager" link will allow me to navigate files on my pc and attach. This is not working with me confused2
you have to have two different websites open at the same time and copy links from one and paste it into another. And that only works after you have downloaded the correct type and size photos to the first website. Words fail to describe insanity.
I have had the same problem for the last 8 years. I just keep cleaning it off.
I don't know how it is supposed to look like but here is a pic of the inside of the cap.
[img]https://photos.app.goo.gl/wzZP5wRS5gmih5Qb9[/img]
Well your seal looks to be there, as A Dab of Oppo says they do seem to weep a bit around the cap base & the warning lable is often damp with fluid on the master cyls on 4 wheel trads, don't over fill as when you submerge the float attached to the cap it raises the level of fluid quite a bit
Edit, just zoomed in on the photo & you can see the fluid just slightly up the neck of the internal filler tube...too much fluid in there matey !
I don't mind keep cleaning it off but my understanding the cap should be tight in order to prevent the brake fluid exposed to air with resultant water droplets formation leading to corrosion of brake lines and seizing calipers
M3W: 2017 green
Caterham: 2003 yellow
Evora 400: 2016 black
SL500: 2005 blue
HD Breakout: 2020 red
If I would like to change the rubber seal, anyone please know where I can get a new seal? or may be a new cap?
M3W: 2017 green
SL500: 2005 blue
You don't need to, your fluid level is too high, see my previous post
As you put the cap on & the float submerges it's burping the excess through the vented cap
It's not actually the case. It may be just the camera angle.
The fluid level is below the max line mark (with the float submerged in)
Yes, my fluid level WAS too high when I bought the car and the leakage was much worse, but now I withdrew some fluid out so the level is below the max line (but it does still leak). In fact in most roundabouts and RT corners the red brake light comes on. So the the fluid shouldn't be any lower.
M3W: 2017 green
SL500: 2005 blue
