0 members (), 249 guests, and 18 robots.
+8Rich 94
Posts837,276
#718794 21/09/21 01:22 PM
P Dron Offline OP
And for my next trick...
I am feeling mildly intimidated by this but I expect I shall get through it somehow.
14 Comments
Good morning it really is a simple home mechanic job, i did mine a couple of months ago, i removed the radiator grill and the bonnet, just give improved access when connecting the hoses, disconnecting the steering rack is easy but please dont make the schoolboy error i made , make sure before disconnecting the rack make sure the wheels are on blocks, and fix the steering wheel in place , i didnt fix it well enough and the steering rack moved slightly resulting in a slightly, im a little CDO, offset steering wheel.
One thing I have noticed with the new radiator is that the engine runs 8 to 10 degrees cooler, which is fantastic ,I still use the Mog for early morning runs in the Dubai summer when the outside temp is hovering around the 40 degree mark (Celsius)
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS
Triumph Thunderbird 2000
Volvo XC 60 x 3
Volvo C30
Hi,
i changed the radiator on my 2009 4/4 last year. Because i had no chance to get it on a lift i've removed to cowl and installed it from top.
Was a little tricky but worked without removing parts from the steering.
But i have maybe a little more space because the airbox was replaced by an cold air intake.
In general the task was easier then expected (for a beginner).
BR
Andreas
2003 Plus 8 35th anniversary, obsidian black
P Dron Offline OP
Thanks for the useful advice. I shall consider all this before taking The Big Leap. Crap plastic rad is still working, so there is no urgency..
Fingers crossed it stays that way Peter. smile
Lot of possible ways. I had the same thoughts about removing the track rods.
So i decided to remove the cowl and switched the radiator from the top. Was
a little narrow and maybe more work - but worked fine. Best for me, i was not
forced to touch steering components.
Btw: Same car - 4/4
