6 members (Burgundymog, MATTMOG, nestor59310, JohnHarris, Supermog, Ruut Bianchi), 238 guests, and 35 robots.
+8Rich 101
John V6 59
Topics49,912
Posts838,163
Georgetoad, woolfie
Page 8 of 12 1 2 6 7 8 9 10 11 12
Originally Posted By 4/4sportsfun
Originally Posted By John +4
You could always build back in a demister
http://www.cbsonline.co.uk/category/Heating__Air_con_and_Ventilation/Demist,b.html
Yes that is what I suggested I would do on the other thread, one or two MOT knowlegeables stated "no need" as far as the MOT is concerned.
I shall fabricate something anyway...
I was reading this article the other day and the following para made me smile
"I had spent a lot of time on the Internet researching peoples’ experiences of the MSVA. As a result I had devised the de-mister system (2 12volt hair dryers mounted in a box under the bonnet and connected to the vents via home made hoses and ducts). Why a de-mister is required for an open top car still defeats me!"
An enormous amount of time was taken fitting and adjusting the windscreen wiper system to make sure it didn’t tie itself in knots when operated! To date they have been used once!
Perhaps we should just whip the screen off and the wipers/washers and see what weight we can get the 4/4 Sport down to instead of fretting about brocken screens waiting
I thought his bit on the wipers quite good too.
Thanks
p.s. Hold onto any surplus 12v hairdryers in case this catches on read
I wonder if the cost of the replacement screen from the factory is for glass only or for the screen and frame? The email I had from Uroglas suggested that as the glass was so fragile and difficult to fit in frame, the screen could only be purchased from Morgan.
Max5 Offline OP
Jay - Screen and frame.
Don.
Maybe yu can send them the old one to fit it into it?
It does seem crazy effectively throwing away the screen frame...far better that Morgan fit a new screen into the existing frame.
Are there any screens broken fitted with an easy up hood? Are the screens used with an easy up hood equal (material and dimensions)? Is it possible that, if the screens material and size is same same, the difference of the frames could be responsible for the issue? I am wondering because mostly the screens are described to crack starting in a corner.
Could different cornering of the two frame types, in case of 9 stud frame, cause internal tension/pressure between screen and frame?
Max5 Offline OP
I suspect that they do and guess who ends up paying for it!
Don.
Just picked this up in the November edition of 'Classics Monthly', Issue 183. On page 19, Classics Monthly are working with a company Tyneside Safety Glass who are said to be confident that they can produce laminated glass in batches for interested clubs and individuals. The contact is Chris Hannant at TSG on 0191 487 5064. email is info@tynesidesafetyglass.co.uk.
The article does mention TSG supplied heating elements to the editors Peerless.
Usual disclaimer is I know nothing about this company other than reading the short article in the above publication.
Ian
Perhaps the MSCC could do a Club "Deal" with this manufacturer to supply the screens at a reasonable cost.
Robbie
2021 Plus Four -- Helga
211-WX-1433
