Topics49,841
Posts837,325
Posts: 1,360 Likes: 5
Posts: 1,360 Likes: 5 |
Ditto (although mine is MY21 hood). I have done a fair amount of sealing round the door/sidescreens using the trusty neoprene strips. Whilst it hasn’t stopped the noise (so my tinnitus always ramps up now!) it is far warmer and less draughty inside so highly recommend it. HB Ps hopefully when they did the suspension on yours, John, they also did the latest rad filler tank “update” - I haven’t looked yet at mine but apparently they have changed the marker showing how full to keep it in order to reduce the issues caused by overfilling
Plus Four Bentley Velvet Red “Grandi P” Golf ehybrid thingy “Toadie” Polestar 4 “Vger”
Posts: 82 Likes: 1
Posts: 82 Likes: 1 |
I changed both tank caps on my Plus Four, the originals from the factory were so dammed tight I could hardly move them. I ordered two from Demon Tweeks, same poundage and the same make, so much easier to put on and off. And no problems with the radiator since.
Heron Grey Plus Four 2021
Previous:- Connaught Green 4/4 1988 Black Plus 8 1998
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
P8mog, Would you please post the specs of the cap you bought and the details of the mod your dealer made. I have the”tight” caps on my car
Posts: 82 Likes: 1
This is the website:- https://www.demon-tweeks.com/uk/stant-racing-radiator-cap-246616/The dealer did nothing, I finally found a small spur on the turbo coolant tank which was stopping it from turning, I was able to get a small screwdriver under the lips on both sides and then a pair of mole grips and finally got them off. The old ones looked like they had been pushed in a bit from the top, the new ones are fantastic and very easy to take on and off. P.S. The lb pressure is on the tops of the caps.
