3 members (Image, Clipper, sprinty), 305 guests, and 39 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,332
Christoph
Page 6 of 6 1 2 3 4 5 6
Ditto (although mine is MY21 hood).
I have done a fair amount of sealing round the door/sidescreens using the trusty neoprene strips. Whilst it hasn’t stopped the noise (so my tinnitus always ramps up now!) it is far warmer and less draughty inside so highly recommend it.
HB
Ps hopefully when they did the suspension on yours, John, they also did the latest rad filler tank “update” - I haven’t looked yet at mine but apparently they have changed the marker showing how full to keep it in order to reduce the issues caused by overfilling
Golf ehybrid thingy “Toadie”
Polestar 4 “Vger”
I changed both tank caps on my Plus Four, the originals from the factory were so dammed tight I could hardly move them. I ordered two from Demon Tweeks, same poundage and the same make, so much easier to put on and off. And no problems with the radiator since.
Heron Grey Plus Four 2021
Previous:-
Connaught Green 4/4 1988
Black Plus 8 1998
Robbie Offline OP
P8mog,
Would you please post the specs of the cap you bought and the details of the mod your dealer made. I have the”tight” caps on my car
Robbie
2021 Plus Four -- Helga
211-WX-1433
This is the website:- https://www.demon-tweeks.com/uk/stant-racing-radiator-cap-246616/
The dealer did nothing, I finally found a small spur on the turbo coolant tank which was stopping it from turning, I was able to get a small screwdriver under the lips on both sides and then a pair of mole grips and finally got them off. The old ones looked like they had been pushed in a bit from the top, the new ones are fantastic and very easy to take on and off.
P.S. The lb pressure is on the tops of the caps.
Previous:-
Black Plus 8 1998
