0 members (),
251
Topics49,911
Posts838,151
Posts: 148 |
I was wondering if any other Morgan owner has lost your car keys, I have a spare set but I would like another set and I was wondering what is the best way to replace them, could I just walk into a shop and get a set cut or do I have to go to Morgan Cars, I would appreciate and help you can give me, Kind Regards Andy.
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6 Audi A4 Advant (some blue colour not botherd)
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The key fob contains a transducer for the immobiliser so although you can get a key cut which will fit and turn, it won't start your engine. Start by talking to your dealer unless anyone else knows a way?
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
They are Ford keys so maybe a Ford dealer. On my S1 Roadster there was a little transducer you could could extract in the key, by default it could also fall out. The 3.7l doesn't have that, just how it works I don't know. .
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
Are you sure the key is Ford?
Freelander rings a bell for the key. They are drilled in the factory to install the immobiliser chip. I believe the immobiliser is Ford.
Mea Culpa. You could be right as the steering column controls are ex Freelander.
Posts: 172 |
By co incidence I asked in my local branch of Timpson's this morning about having a transducer key cut for a dally driver. They scanned key and are able to say straight away if they can make a key or not. They need the car present to match to.
They could do a key for a 11 year old Indian car so a Morgan should be no trouble!
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
If…. your Roadster has a Ford ecu with a PATS immobiliser and you have two original (non clone) keys you may be able to program more immobisier chips using the ECU’s built in functionality. Then if you can find a Landrover key blank and have it cut its just a case of drilling a hole for, or attaching the new chip. This old thread might help.
Roger 2011 Plus 4
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
May be worth a chat with your local Landrover dealer, especially when the parts dept sees it's a Mog parked outside and a bit of a different challenge ?
