3 members (JohnHarris, Player99, mph), 244 guests, and 34 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,146
#730177 14/01/22 02:12 PM
stumog Offline OP
I was wondering if any other Morgan owner has lost your car keys, I have a spare set but I would like another set and I was wondering what is the best way to replace them, could I just walk into a shop and get a set cut or do I have to go to Morgan Cars, I would appreciate and help you can give me, Kind Regards Andy.
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6
Audi A4 Advant (some blue colour not botherd)
The key fob contains a transducer for the immobiliser so although you can get a key cut which will fit and turn, it won't start your engine. Start by talking to your dealer unless anyone else knows a way?
They are Ford keys so maybe a Ford dealer. On my S1 Roadster there was a little transducer you could could extract in the key, by default it could also fall out. The 3.7l doesn't have that, just how it works I don't know. .
Are you sure the key is Ford?
Freelander rings a bell for the key. They are drilled in the factory to install the immobiliser chip. I believe the immobiliser is Ford.
Costock, UK
Disco 5
Mea Culpa. You could be right as the steering column controls are ex Freelander.
By co incidence I asked in my local branch of Timpson's this morning about having a transducer key cut for a dally driver.
They scanned key and are able to say straight away if they can make a key or not.
They need the car present to match to.
They could do a key for a 11 year old Indian car so a Morgan should be no trouble!
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
Rog Offline
If…. your Roadster has a Ford ecu with a PATS immobiliser and you have two original (non clone) keys you may be able to program more immobisier chips using the ECU’s built in functionality. Then if you can find a Landrover key blank and have it cut its just a case of drilling a hole for, or attaching the new chip. This old thread might help.
Roger
May be worth a chat with your local Landrover dealer, especially when the parts dept sees it's a Mog parked outside and a bit of a different challenge ?
