6 members (lord-richfield, Topline123, John07, mph, MartinB60, CooperMan), 289 guests, and 40 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,342
Members9,215
Page 125 of 300 1 2 123 124 125 126 127 299 300
+8Rich #730539 18/01/22 07:21 PM
E
E
Nothing to smile about but.... AC12 Interviews Johnson
https://twitter.com/i/status/1483418498944671746
+8Rich #730542 18/01/22 07:30 PM
[Linked Image<br>Now we stand a chance</div>
<br>
</div>
<div class=
2025 MG ZS EV aka Trigger
I'm just re-watching Line of Duty!! That was brilliant.
Best Regards
Lang may yer lum reek
+8Rich #730546 18/01/22 09:33 PM
+8Rich Offline OP
A couple of crackers there John and Euro thumbs
For those of us not on Twatter https://www.youtube.com/watch?v=H0QD-wvNmE4
2009 4/4 Henrietta
1993 Connaught Green +8 prev
+8Rich #730554 19/01/22 02:17 AM
thumbs That was excellent! grin2
'09 Gen2 MINI Cooper ragtop
Paul F #730562 19/01/22 08:52 AM
Originally Posted by Paul F
Who is your favourite narrator from the Rocky Horror Show?
Charles Gray.
Best Regards
Charles Gray.
I think we saw him in Nottingham once. He was very good.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
+8Rich #730643 20/01/22 09:52 AM
TOOLS EXPLAINED
PILLAR DRILL : A tall upright machine useful for suddenly snatching flat metal bar out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
MOLE GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH : Used almost entirely for setting on fire various flammable objects in your workshop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
HYDRAULIC JACK : Used for lowering a car to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW : A large stationary power saw primarily used by most people to cut good metal sheet into smaller pieces that more easily fit into the bin after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to butcher Phillips screw heads.
STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: See Screwdriver
HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
STANLEY KNIFE : Used to open and slice through the contents of parcels delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
ADJUSTABLE SPANNER aka "Another hammer", aka "the Swedish Nut Lathe", aka "Crescent Wrench". Commonly used as one size fits all, usually results in rounding off nut heads before the use of pliers. Will randomly adjust size between bolts, resulting in injury ,swearing and multiple threats to any inanimate objects within the immediate vicinity.
BASTARD TOOL : Any handy tool that you grab and throw across the garage while yelling BASTARD at the top of your voice . It is also, most often, the next tool that you will need.
+8Rich #730645 20/01/22 09:59 AM
All so true.......
+8Rich #730646 20/01/22 10:10 AM
To this day one of my pals who is a carpenter calls screws ‘rotary nails’ and says screwdrivers were invented to dig them out with 🤣.
BR
Colin
BR Colin
