Topics49,869
Posts837,665
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
Thanks for your replies must be a gremlin. I tried pressing the inertia switch to perhaps reset things but what happens is that the car is totally isolated with electric power which is what would happen in a collision and you have to physically reset the mechanical switch to restore power, but the light is still on unfortunately. Have you tried tripping the circuit breaker on the front of electrics box. I know some owners use this to save the horrendous battery drain when car laid up for more than a few days. Apologies if that is what you meant by mechanical switch. I’m on my 3rd Aero and only discovered this switch 6 months ago. It’s a godsend and saves plugging a C-tek in
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 2,433 Likes: 66
Posts: 2,433 Likes: 66 |
It's the best switch on the series 1 and it always works......
Posts: 40 |
tried resetting the inertia switch but it didn't clear the fault
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
I’m on my 3rd Aero and only discovered this switch 6 months ago. It’s a godsend and saves plugging a C-tek in Agreed but beware it's effect on radio memories on the sound system and if you have a tracker fitted. I had a lovely old Becker and once the power was cut with the isolator switch it lost configuration and also went back to the old 80's anti-theft code on restart. It was a devil to find the code again.
