10 members (CooperMan, Morganmike, DaveW, MJF, Mike D, PaulV, +8Rich, Moggo, sprinty, John Winn),
276
146
Topics49,869
Posts837,658
Posts: 40 |
Has anyone experienced the Inertia Switch Warning Light suddenly for no reason illuminating but not causing a problem but will not extinguish until eventually timing out after removing the ignition key.Is this another quirky happening with the Aero
Posts: 11,532 Likes: 318
Posts: 11,532 Likes: 318 |
Which one is the Inertia Switch Warning Light ?
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
If I understand it correctly the inertia switch cuts the fuel pump in the event of a collision or roll over. If your engine was running normally during this anomaly, then likely to be just another Aero electrical gremlin.
I've had the similar with the handbrake and seatbelt warning lights too.
David Aero S4
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
My inertia light is on quite often. Mind if it’s own
Series 1 though
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 535 Likes: 1
Posts: 535 Likes: 1 |
That's bound to be the integration of BMW CanBus in to Morgan wiring
Cheers, Paul
Posts: 40 |
its the exclamation mark ! warning light that comes on the dashboard
Posts: 40 |
Thanks for your replies must be a gremlin. I tried pressing the inertia switch to perhaps reset things but what happens is that the car is totally isolated with electric power which is what would happen in a collision and you have to physically reset the mechanical switch to restore power, but the light is still on unfortunately.
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
Simon have you tried the reset button. This should clear the fault that's turning on the light?
Slowly going green
Posts: 535 Likes: 1
If you have one of those OBD port diagnostic tools you may be able to clear the fault code from the ECU that way and the light would then go out.
Cheers, Paul
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
Thanks for your replies must be a gremlin. I tried pressing the inertia switch to perhaps reset things but what happens is that the car is totally isolated with electric power which is what would happen in a collision and you have to physically reset the mechanical switch to restore power, but the light is still on unfortunately. Have you tried tripping the circuit breaker on the front of electrics box. I know some owners use this to save the horrendous battery drain when car laid up for more than a few days. Apologies if that is what you meant by mechanical switch.
