10 members (Burgundymog, Clipper, Sir Percival, GrumpyPa, gaston, Soleng, DCH, DJC, Ncik P, eds),
314
56
Topics49,837
Posts837,286
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Éthanol conversion on the way
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Not entirely sure what I'm looking at but shouldn't the fuel pressure be at 58psi?
Posts: 34 |
It appears that a picture is NOT worth 1,000 words.
It's a BAR gauge which looks like it's reading 75 PSI. If it is really reading 75 PSI, something is very wrong.
Will the "Talk Morgan Expert" articulate what problem is being solved here?
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
It looks like you have replaced the Mahle KL167 filter/regulator with a regulator that maintains about 75psi, or 5.4 bar. Not sure why you would do that? Pretty sure that the Mahle KL167 will work fine with E10 fuel. Have you fitted another inline filter in the system?
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Éthanol conversion on the way So does this need the extra pressure?  Looking forward to hearing more!
There was no. Change on the fuel Line There is 5,5 bar And the engine start And run very well
