0 members (), 196 guests, and 93 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 4 of 4 1 2 3 4
Rimmer bros were my go to source of bits for my T16.
Oddly enough, I've been getting M16 bits from ebay.co.uk (company is latvia or lithuania). He seems to have cornered the market on M16! The improved t16 head gasket can be used on the M16 with modifications if you believe the youtube videos. They also had complete M16 gasket sets including valve seals. I've had my winter project list lined up for the 40K service. I believe these are the right numbers. I'm going to be fitting them over the next few weeks. (no interest in the dealers)
LT77 gearshift bushings: TDC automotive / SuperPro Poly Gearbox Gearlinkage Selector Car Bush Kit High Stability SPF0355K
waterpump: carpartsinmotion / QHazel 2411680RMP
idler pulley: autospares.eu / SNR GE361.10 Deflection/Guide Pulley, timing belt for ROVER
tension pulley: mjd128 / INA 531 0077 10 Polea Tensora Correa de Distribución (60mm diameter verified against idler pulley)
cambelt: stockparts245 (latvia) / CT543 continental
Thermostat: rimmer / 13H7604 OE THERMOSTAT
Originally Posted by ksudak
Thanks John. It does have a distributor. I'm looking for seals and gaskets for this engine. Any thoughts for a parts source? I'm at a loss.
Hi Ksudak
re source for seals and gaskets; try F W Thornton, their # 01952 252 892 website: fwthornton.co.uk
I just ordered a full head gasket kit for M16 last week along with complete set valves (see my recent post on timing belt issue under Maint & Servicing)
Rimmers had some separate gaskets but not the full kit.
Good luck.
Col
Page 4 of 4 1 2 3 4
