Topics49,901
Posts838,043
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
The standard low melting point solder should work ok. Keep heat as low as possible and directed onto the back if possible after initial warming it up. That way you can minimise heat discolouration that you will need to polish away.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Rather than using the expensive Belzona I'm sure two pack Araldite would work ok on a grille. Once upon a time a friend and I were trying to fit a Fish or Minnow Fish carburettor to a VW Beach Buggy, we either couldn't get or couldn't afford a propriety inlet manifold so we Araldited the new carb to the original manifold. Worked!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
JB Weld is another possibility.
Posts: 502 |
Or plastic padding super steel.
2004 Series 1 Roadster
