2 members (Chris Cosher, JohnHarris), 291 guests, and 37 robots.
+8Rich 92
Posts837,277
Page 3 of 4 1 2 3 4
Full lights
Just noticed the red gasket on mine has rotted as well, where did you get your replacement from Red 3.
I just cut mine from some Viton sheet I had lying around but much easier to go to SiFab on eBay but I didn't know that at the time!
2020 M3W
JohnMat #732765 08/02/22 07:46 PM
Those are nitrile not Viton rubber
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
SimonH #732781 08/02/22 10:41 PM
According to the Q&A on Amazon US, the 'Manufacturer' stated "These are Neoprene a synthetic rubber.". No idea how dependable this response is of course.
Is Viton Rubber the preferred solution over nitrile or neoprene? I'd like to avoid this happening again!
2020 M3W
First try with éthanol the engine run well
Exhaust température 800 °C
Fuel pressure 5,5 bar
Is it 100% ethanol or the E85 that you are running? Should be able to get some serious power once set up properly for either.
did you measure the exhaust temps before going to ethanol?
Why such high fuel pressure, have you changed the injectors?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Page 3 of 4 1 2 3 4
