1 members (sewin),
159
40
Topics49,838
Posts837,294
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
![[Linked Image]](http://img113.xooimage.com/files/9/8/3/ae4bd9c9-c5c2-43...b0b29c6-58d1dcd.jpeg) Full lights
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Just noticed the red gasket on mine has rotted as well, where did you get your replacement from Red 3.
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Just noticed the red gasket on mine has rotted as well, where did you get your replacement from Red 3. I just cut mine from some Viton sheet I had lying around but much easier to go to SiFab on eBay but I didn't know that at the time!
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
2020 M3W
Posts: 1,415 |
Those are nitrile not Viton rubber
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 296 Likes: 3
Those are nitrile not Viton rubber According to the Q&A on Amazon US, the 'Manufacturer' stated "These are Neoprene a synthetic rubber.". No idea how dependable this response is of course. Is Viton Rubber the preferred solution over nitrile or neoprene? I'd like to avoid this happening again!
2020 M3W
First try with éthanol the engine run well Exhaust température 800 °C Fuel pressure 5,5 bar
Is it 100% ethanol or the E85 that you are running? Should be able to get some serious power once set up properly for either.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
First try with éthanol the engine run well Exhaust température 800 °C Fuel pressure 5,5 bar did you measure the exhaust temps before going to ethanol?
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
First try with éthanol the engine run well Exhaust température 800 °C Fuel pressure 5,5 bar Why such high fuel pressure, have you changed the injectors?
