Topics49,904
Posts838,079
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
i wonder why the swirls on the inside of the covers?
Posts: 365 Likes: 37
Posts: 365 Likes: 37 |
Think they were circa £300 last year/year before via another seller - same 7 sets...along with the Hesketh Cam chest covers. (edit - just noticed the email address given - the cam chest covers were sold by a bike breakers)
They do look nicely different in black, but only the bare ones are available on ebay. (were but it now seems they are no longer available?)
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
To create a vortex driven by the movement of the cam belt. This in turn expunging the belt dust and so increasing belt life. I could be wrong though
Posts: 439 Likes: 3
I'd suppose for some minor additional surface area for oil cooling transfer, and because with a CNC and CAD, it's easy to do :-)
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
Whatever the (technical) answer is, they look wonderful. Just promise you won't pop-rivet on some "Morgan" plaques, which appears to have been done to this Aero Supersport which has been for sale for ages for some reason(s).... ![[Linked Image]](https://www.tm-img.com/images/2022/02/09/Morgan-Aero-4.8-Supersport-rocker-cover.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
To create a vortex driven by the movement of the cam belt. This in turn expunging the belt dust and so increasing belt life. I could be wrong though  If your cambelt is in the rocker covers I think you will find you have other problems
Posts: 382 Likes: 3
Posts: 382 Likes: 3 |
The "swirls", are tool path marks replicating the cnc program
The "swirls", are tool path marks replicating the cnc program a nice big, deep, spiral cut. Engine turned marks on the mating surface look good and serve a function but the concentric spiral is still a mystery to me. They look like cast into the underside of the cover and maybe it is to add rigidity. They also would let the oil that splashed up onto the covers to drop back down more randomly rather than run toward the edges.
Posts: 62 |
The spirals are just machining marks left by the cutting tool as it is rotating along a spiral path. There will be very little evidence by feel and will be smooth, what it does do is show the tool path used and the reflections from the aluminium
