12 members (DCH, Graham, G4FUJ, JamesS, MartO, Joske Vermeule, TeddyAds, sewin, cerealsurfer, High Hamster, BLUE+4, Alistair, BobtheTrain),
307
62
Topics49,860
Posts837,522
Posts: 28 |
Gentlemen i have a Plus 8 and thinking f putting Electronic ignition in place instead of distributor etc.Any advice?
Has anybody any experience of this? Any recommendations on make or model?
Much apprciated
Audi A8 4.2 Jaguar XKR Golf Morgan Plus 8
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
You don't say what year your +8 is or what type of Dizzie you have, I assume it is an early +8 with a Mallory dual point dizzie? You could put in a Pertronix Ignitor with a Pertronix Coil, the Pertronix website is informative, a good timing light to set up the correct timing should set you straight.
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
As above we really need to know what year your car is and whether you have carbs or injection. The early cars had a single point lucas distributor which was acknowledged as a weak point even in the 60s/70s. Many converted to Mallory Dual contact , (expensive) or even Unalite (very expensive) but that meant replacing the whole unit. Pertronix was one solution that involved replacing just the breakers BUT as above you also need their coil. Not sure of the year , but eventually even Lucas did away with points and went electronic, again it was not a great system but generally thought to be "good enough". This was used on all the injection cars (13 CUX and 14CUX) right up to 2001/2 The last +8s (2001/2 onwards) used the GEMS system which did away with the distributor completely, the ecu handled the fuelling and ignition. There are various suppliers who can do a similar system for you eg https://www.lloydspecialistdevelopments.co.uk/products-upgrades/engine-management-kits/ at a price. Many speak very highly of these systems. They can be almost individually programmed, use 2 different maps for differing purposes, and will minimise both emissions and fuel consumption.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
I used a Lumenition on a Stag V8 - worked well and without problems.
Posts: 76 |
A conversion to a Ford EDIS worked a treat an E-type for me a few years ago. Fully electronic and eliminates the dizzy completely.
Tom Morris 1972 Plus 8 1932 Super Sport "Beetleback" 1961 Morris Minor Tourer 1972 Triumph T120V
Posts: 6 |
I have used the 123 distributor and ignition. It works super well and reliable. Has a handy app which exports all relevant engine data to your phone.
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
Maybe worth a chat with these guys in Shrewsbury, https://www.tornadosystems.com/or RPI Engineering in Norwich
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
I’m in the process of installing 2x VW 4 cylinder spark modules working off a timing wheel instead of the distributor just the finishing touches to do - hope to finish this weekend
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 514 Likes: 56
Posts: 514 Likes: 56 |
Smudger, what type of ecu are you using to control the timing?
David Byrne
Posts: 238 Likes: 3
It’s using MegaSquirt, things haven’t gone to plan this week so I haven’t had as much time with car as I expected , however I’m hoping to install the static map , then the dynamic map followed by a session on a rolling road, 2 maps one track & one MOT/economy
