0 members (), 374 guests, and 34 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 4 of 4 1 2 3 4
No it is to show the rubber
Are you trying to show the wiper arm is too easy to lift from the 'screen ?
This photo was taken by me to show Peter that the straps fit snugly on the arm. I am very happy with these wiper blades.
Originally Posted by Derek596
Collected my Plus Four today, fitted Librands wiper blades LIBR996 & 995 and am most disappointed. Just as bad as the ones supplied by Morgan. Anyone else disappointed?
Please describe your problems a little bit -perhaps we can support you a little with hints.
I use the wiper blades from only problem I had, was that the rubber was 2mm to long. A cut with a sharp knife resolved this problem for me.
I only had to cut one corner of the rubber off. Now I am very pleased with the result. This blades work much better than the original ones.
Although for ease of removal the OE tapered, splined wedge type are best, there are wiper arms that have matching female splines within arm mount with a spring clip that locks them onto splined shaft. I have Caterham ones on my Roadster with this fixing. As well as main arm spring being a little stronger they lock out at 90° to screen to aid cleaning.
MR11MOG Offline OP
If you have a 2022 model car then 3x200mm should work fine .No one else has had a problem .
Peter.
Aero plus8 50th Anniversary.
Page 4 of 4 1 2 3 4
