8 members (M3WMW, JMcL, John Winn, TBM, Black Adder, Strathaven, bmgermany, RichardV6),
226
32
Topics49,908
Posts838,124
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
Nick, here`s one link. I`ve used a couple of others in the past, and there are more compact ones available for motorcycles also. https://hhokit.ie/I`m not endorsing anything, due diligence and your own judgement are required obviously.  Regards Phil
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
KoH, Potassium Hydroxide, is commonly known as caustic potash. Not sure I would want to inject that into any engine I cared about.
Also, the math/chemistry behind this product is improbable enough to be called bogus given the small energy input (24-36watts). Separating hydrogen from water takes megajoules of energy per liter. KoH should be similar.
There's a reason this 'technology' is not in wide use.
Steve Late 2012 M3W
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Hi Nick
I made up a small injector from brass bar and fitted it in a sandwich plate between the carburettor and inlet manifold. A piece of plastic micro-bore tube then connected this to a needle valve flow restrictor which drew water from a windscreen washer bottle mounted on the inner wing.
The bottle was then filled with water with a few drops of washing up liquid (to reduce the surface tension). The vacuum under the carb. sucked water through and the flow rate adjusted with the needle valve.
Many weeks of experimentation with flow rates resulted in some rather fascinating findings regarding performance/economy. None of this is scientific just britches arse engineering. But it worked.
If I remember correctly, an introduced air bubble would travel through the tube 1" over 1 minute on tickover for the best result. I could easily get 35mpg out of my 1600 X-flow when all my mates were struggling to get 30.
Unfortunately I cannot remember the size of the hole in the injector or the bore of the tube I used, it was small though 1-2mm at most. Just some stuff we had kicking about at work.
Things you do when you're young, daft and skint.
