7 members (IcePack, MATTMOG, mph, John07, Sloany, +8Rich, JohnHarris), 290 guests, and 41 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,992
RedThree
#736356 17/03/22 03:17 PM
Leroy Offline OP
I've just installed some new clear indicator lenses to the rear of my morgan as for some reason the previous owner had only replaced the front ones with clear lenses.
I was in wilkos earlier today and saw some orange bulbs so got them prior to installing them.
However, as can be seen from the below image, the bayonet lugs are off centre. I've went onto wilkos website and seen an image of a clear bulb, also with the same off centre lugs. I can't see the why such a thing should be in existsnce. Surely that would mean it might sit off centre when installed. Needless to say, it wouldn't fit properly, so luckily I had some spares.
2004 Series 1 Roadster
It's done so a clear bulb cannot be put into a holder that has an orange lens which has been changed to clear. I had the same problem but the correct orange bulbs are available.
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
I bought mine from classic car LEDs they do both sorts as orange bulbs.
2025 MG ZS EV aka Trigger
TBM Offline
Yep - when a manufacturer uses orange bulbs/clear lens, they usually have offset pins to prevent people putting clear bulbs behind a clear lens.
If you are converting orange lens indicators to clear lens you need to find orange bulbs with opposite pins. I use 'chrome' bulbs - they are silver in appearance but light up orange - it avoids the 'fried egg' look.
Amber Offset Bulbs usually have the code 581, Amber Straight Bulbs are 382.
Leroy Offline OP
Well that does make sense. Yes, the code 581 is on the packaging. Best get some spares ordered.
Much prefer the clear lens look. Thanks guys!
There are many bayonet car bulb base variants, see here. Single filament with the common 15mm base are BA15s or 382 and dual filament (stop/tail) bulbs BAY15d or 380 on most Classic Mogs. Obviously the wattage has to be correct for purpose as well in the case of filament bulbs.
An alternate to orange filament indicator bulbs are no hyperflash amber LED's which won't affect the flash rate.
ETA: note that 581 type although single filament have radially offfset pins so won't fit. You need 382 type as above.
Leroy Offline OP
Think I'll order from the place Richard and John suggest. Guess with them being LED, they'll last longer.
Yep those are the ones. They are excellent.
Black Rat
Black Rat
I fitted clear lenses to the front only I thought clear lenses on the rear looked odd.
Keith
2013 narrow bodied + 4 Ruby.
Leroy Offline OP
Bought some. Pricey, but if it means I have to change them less its a bonus as those little brass connectors that keep getting pushed into the base plate are annoying 😂
